Dear all,
How to remove the unwanted entities, while converting PDF to Autocad using Autocad software import option?
I have converted original PDF file to AutoCAD file using AutoCAD 2018 software (Using Import option) . I got the Autocad format file with the following issues.
The converted file contains lot of unwanted entities other than my converted pdf entities.
Kindly fix the above issues.
Requirement:
I have more than 2000 pdf files for Autocad conversion. If i work on each file, it consume more time to remove the unwanted entities. That is a time consuming process.
Is there any lisp / shortcuts methods available to avoid the above detailed issues.
I attached 2 images with red markups for your reference.
original pdf
converted pdf 2 cad
Thanks in advance.
