Dear all,
How to remove the unwanted entities, while converting PDF to Autocad using Autocad software import option?
And how to fix the hidden lines from separate line?
I have converted original PDF file to AutoCAD file using AutoCAD 2018 software (Using Import option) . I got the Autocad format file with the following issues.
1. The converted file contains lot of unwanted entities other than my converted pdf entities.
2. The hidden lines are showing as separate lines.
Kindly fix the above issues.
Requirement:
I have more than 2000 pdf files for Autocad conversion. If i work on each file, it consume more time to remove the unwanted entities and to fix the hidden lines from separate lines(entities). That is a time consuming process.
Is there any lisp / shortcuts methods available to avoid the above detailed issues.
Thanks in advance.
