How to remove -Model from PDF names.
David_Monnens
David_Monnens
I do a lot of batch processing of Autocad drawings, to save time is there a way to remove -Model from the pdf names? I would just like to plot is as the drawing name. It takes a long time to remove -Model from every single pdf before or after it is batch processed. I know there are 3rd party apps that can do this for me but IT will not allow them to be installed. Thanks!
Patchy
Use DOS rename, there are many tutorials on the web.
Back to the old CMD command.
pendean
Community Legend
Community Legend
If you only use PLOT command, you will need to manually rename the output files or develop a lisp to do the work for you. You can find these lisp routines all over the web and in the dedicated LISP forum too, help yourself with a search https://forums.autodesk.com/t5/autocad-customization/ct-p/AutoCADTopic1
If you use PUBLISH command, you can rename (and save for future reuse) the output there. But you crippled yourself by only using modelspace for plotting I gather, so that built-in tool is probably limited in help you out. But give it a try though, you never know. We all use paperspace 20+years since its introduction and we automate well with PUBLISH and SSM tools that are built-in.
Or, as you noted, ask your IT for a Windows based file renaming app to use all the time after file creation.
natasha.l
Hello @David_Monnens
By default it will use the file name  unless you >change the default<. Please select the Sheet Name > Right-click > Rename Sheet.
Please "Accept Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
