Anuncios
How to Remove a cloud in AutoCAD 2014 drawing
No aplicable
How to remove the cloud and triangle symbol in cad drawings.
Herewith , i have attached the sample drawing for clarification. Please advice.
Thank You.
@Anonymous, john.vellek has edited your subject line for clarity:Hoe to Remove a cloud in cad drawing
0 Me gusta
Responder
1.824 Vistas
8 Respuestas
Respuestas (8)
Discussion_Admin
If you can let me know what product you are using I can move you post to the appropriate forum to get you better feedback
Discussion_Admin
0 Me gusta
No aplicable
Am using Autocad 2014 Version.
Kindly do the needful.
0 Me gusta
Sofia.Xanthopoulou
Unfortunately @Anonymous you have attached only a picture, not the drawing.
Just curious... can't you erase them?? Anyway, please upload the DWG file and I will take a look what is going on with those objects.
Regards
0 Me gusta
No aplicable
Here with, i have attached the sample drawing for further clarification.
0 Me gusta
Alfred.NESWADBA
Sorry, no drawing attached, please don't use your mail system, answer directly in the forums thread using your internet browser and >>>that link<<< ==> REPLAY
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2025
(not an Autodesk consultant)
0 Me gusta
No aplicable
Please find the attached sample cloud drawing.
 Have to remove the cloud in more drawings.
Thank You
0 Me gusta
Alfred.NESWADBA
this drawing is not an AutoCAD drawing, which software has saved the dwg (or has been used for some modifications)?
Almost all objects like dimensions, labels, section labels, bom-table, most of the geometry objects ... all they are anonymous blocks, I would say this drawing is in a state you can't normally work with AutoCAD. Either this dwg-file was created with a very different product or, if it was AutoCAD there was an application on top of AutoCAD that takes all ways to hide the data from normal modification tools (and so make the drawing unusable)
Also the rev-clouds are no AutoCAD revision clouds, they are made as anonymous blocks and on layer 0, so there is also not an option to select them automatically (without development). You need to select them manually and press <DEL>.
[EDIT] just have seen that the rev-clouds do have their "cloud-geom" on layer "Graphic object", freezing that layer hides them [/EDIT]
Sorry, - alfred -
Alfred NESWADBA
0 Me gusta
Sofia.Xanthopoulou
Hi @Anonymous,
if Alfred has got a point here, all reader would appreciate a feedback from you. Please share your experiences. How did you solve this issue?
If you need any further assistance on this particular drawing, please do not hesitate to ask.
Regards
0 Me gusta
