How do I specify a location for my auto save files to go? I'm on a network and I would like to be able to save my files to a location on my computer, not the network.
Now I have to jump through all sorts of hoops to restore any files and usually they are a couple of hours old, even though I am set up to save every 10 minutes.
Sounds like this should be something simple to do, but I think because I am on a network, I'm having problems.
Please help.
Thank you,
E.J. Roell
Solved by Cadologist. Go to Solution.
Please help.
Thank you,
E.J. Roell
They are saved in the Temporary Drawing File Location specified in the Files tab in the Options dialog.
I keep mine in C:\Temp\
Use OPTIONS command > FILES tab > AUTOMATIC SAVE FILE LOCATION (see pic)
Yes... but I am on a network, so I see users\me\appdata\local\temp.
I would like them to be on my computer only so I dont have to search through all the extra files on the network
C:\users\me\appdata\local\temp is on your computer. You may have to make hidden files and folders visible in windows explorer
Oops, see User181 for the correct folder. I had forgotten that one.
You can enter a different path for the folder location.
Autosave exists to provide recovery from a catastrophic failure of some kind, so when the time between PROPER file saves exceed the SAVETIME variable a $SV file is written to the directory you specify in the SAVEFILEPATH. Changing the SAVEFILEPATH changes the location of autosaved files. We force all SAVEFILEPATH's to local drives, specifically C:\AUTOSAVE
Now when the file is subsequently PROPERLY saved the $SV files are deleted (as they should be). However if you have create BAK enabled, and you've failed to properly save your file for over TWICE the SAVETIME setting the earlier $sv file is renamed *.BAK and a new $SV is created.
I would suggest a habit of CTRL+S every few commands and autosave will fade into much less importance.
As an option, you could add some basic code (lisp) to a button on a tool palette so users are 'standardized' in where the Autosave location is located; or just run a simple lisp. This can be added to a corporate configuration lisp that users could run when setting up their workstation for your company, which could include a variety of other pathing requirements, templates, trusted sites, plotting configs, etc.....
Code example (below):
; Temporary file location for Auto Save
(setvar "SAVEFILEPATH" "c:\\temp\\autosave")
Link to the Autodesk Knowledge Network for SAVEFILEPATH (system variable)
Chad Franklin
