too late again, but it was already wrote:
>>"I added luprec and auprec to the, imo completely useless timewasting invention called sysvarmonitor"
If you don't want to monitor a sysvar, turn it off (I know, that is what you do for usual)
and it waste zero seconds anymore.
>>"and see that those have preferred values"
>>"I have no idea where those come from"
Beside the listed sample variables of a standard installation, YOU set the default value.
If you add a variable to the list, the default value is the current one of this moment, but you can set it different.
>>"nor why we need that anyway."
Because of two things
1. If you can't remember your favorite value, you see it directly, but there is one more reason:
2. one option of sysvarmonitor is, you can set all variables to your favorite value by one click [Reset all]
Note your picture showing that you don't talk about Autocad (what we discuss here, in the AutoCAD board. C3D is the next door with a dedicated board)
It's always good to inform the community about the used software, Productname and Version!
Share your detailed Productversion of AutoCAD and Civil3D, command: ABOUT
>>"it jumps back to 3 decimals and tells me that there are now less sysvar's with unpreferred values."
>>"So just stretching something makes that happen.
>>"I'm pretty sure it's caused by this thicked option
AECDWGSETUP incl. automatism which are not in AutoCAD (I am familiar with ACAD, not with C3D)
(I was not able to reproduce this issue by grip-stretch option, I tried it with a closed polyline from command rectang)
