How to permanently hide the objects or isolate??
Message 1 of 15
Dear All,
          I Need Help from yours, how to Permanently hide the selected object.
If we use Isolate command that one temporarily only showing, i want to show selected objects.
i want to permanently hide the object.  I attached the photos.  before isolate and after isolate  upload-1.JPGupload-2.JPGupload-3.JPG
Anyone please help me for find the solution.
My Email id: yraj2795@gmail.com
Replies (14)
Message 2 of 15
Alfred.NESWADBA
>> I want to permanently hide the object
Is command _HIDEOBJECTS (>>>details<<<) the command you are looking for?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 3 of 15
ennujozlagam
ooopppsss sorry wrong forum. thanks
Message 4 of 15
cadffm
plain AutoCAD?
While there is a possibility to do so, only you would know about it and another user would have big problems
even you if you forget that there are other (hidden) objects.
So I just want to say that programming has this possibility
but I do not support this wish.
Structure your file differently to get to that goal,
eg you could cut a block or Xref with XCLIP.
The command and the command to change and delete clips are documented for each user and
would be a better choice in this case, at least one that I can support 😉
Sebastian
Message 5 of 15
Dear Sir,
             HIDEOBJECTS Command also not permanently working. its that temporally only hide the objects.
after completion of  HIDEOBJECTS i go to save and Re-open the drawing,  again the HIDEOBJECTS are showing.
i want to permanently hide the object.   it's like a WBLOCK Command method.
Message 6 of 15
Alfred.NESWADBA
Sorry not having understood your "permanently" that way.
In that case change these objects to layers which are frozen.
- alfred -
Alfred NESWADBA
Message 7 of 15
Sir,
       or-else  say that how to permanently hide the object.
It's like a freeze the element type.
Message 8 of 15
permanently means after saving of DWG file, reopen the same drawing i want to show only selected objects. Now unselected objects are hiding....
Message 9 of 15
Alfred.NESWADBA
>> permanently means after saving of DWG file, reopen [...]
Please look then to post 4 from @cadffm
- alfred -
Alfred NESWADBA
Message 10 of 15
Kent1Cooper
@Anonymous wrote:
....  or-else  say that how to permanently hide the object.
I agree that you should put them on Layers that you can Freeze, or define them all [on their original Layers] into a Block, and put that Block on a Layer you can Freeze.  [Or... the truly permanent  way would be to ERASE them....]
Kent Cooper, AIA
Message 11 of 15
qnologi
Message 12 of 15
pendean
Community Legend
Community Legend
permanently hide? Try ERASE command, about as permanent as it gets.
Or XREF this file into a new dwg, then XCLIP command out what you never want to see in that file ever again until you change your mind. This leaves the original intact.
Or WBLOCK out what you want to create a new file, then do whatever you want there.
Message 13 of 15
ArchD
Yeah, I was going to say, if there is not meta data that you are using in fields related to these objects, why not just delete them? Why keep data around if it's not being used? I never understood that.
Archie Dodge
Applications Expert - Infrastructure Solutions Division
IMAGINiT Technologies
Message 14 of 15
john.vellek
Hi @Anonymous,
The easiest way to do this might be to just block the entities out to a separate drawing.
Using VBA you can set the objects to invisible. If you would like me to move this thread to the Visual Basic forum let me know and I can get it moved for more suggestions from that community.
John Vellek
Message 15 of 15
Paul_Gander
Is this the setting you are looking for?
ObjectIsolationMode.PNGhttp://help.autodesk.com/view/ACD/2019/ENU/?guid=GUID-B4ED98BE-62D0-4982-82A2-87B744C56F99
