How to open this .sldasm file?
Can anybody open this in autocad?
https://grabcad.com/library/epicyclic-bevel-gear-reducer-1
I keep getting 'import failed'.
I'm in need of the the whole assembly.
Cadologist
Gave it a shot, let me know....
I used the following workflow via the Autodesk Knowledge Network
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/How-to-c...
No issues or errors on the import using AutoCAD 2017 and the above workflow.
Chad Franklin
That's the same process that I usually use to import solidworks files off of grabcad, not sure why I keep getting an import fail in my Autocad 2016.
Doesn't matter tho since you supplied the dwg, thanks!
Cadologist
No problem, good for me also as I haven't had to import a Solidworks model for a while, good refresher. Also, I wasn't aware of the GrabCAD website, now I do, thanks for the kudos, have a great day!
Chad Franklin
JDMather
What version of SolidWorks were the files created in (AutoCAD 2016 will read up to SolidWorks 2015).
What version of AutoCAD is @Cadologist using?
Cadologist
I used AutoCAD 2017 to import the sldasm file, no errors on the import, did a save as to AutoCAD DWG version 2013 (typical for 2013 through 2017) file type. I am unsure what version the Solidworks file was/is.
Chad Franklin
