how to open more than one drawing with autocad 2019
how to open more than one drawing with autocad 2019.  I have to close the drawing and open the other.  Just got acad2019 up and running.
Johanna_Esteban
Hi @Anonymous,
Please drag from explorer to your AutoCAD what you need, you should open all you have selected.
Johanna Esteban
Autodesk Expert Elite | Autodesk Certified Professional | AutoCAD Customer Council (Beta Tester for Windows & Mac)
¿Te ha parecido útil este post? ¡Dame Kudos! 😉
Si ha sido resuelta tu inquietud, selecciona 'Marcar como solución' para que otros usuarios la encuentren fácilmente.
Johanna_Esteban
Hi @Anonymous,
Johanna Esteban
user181
If you can only open 1 drawing at a time maybe you need to set the SDI variable to 0
ennujozlagam
open your autocad > > open > drawing > go to your folder > use ctrl in your keyboard and highlight all your file want to open. thanks
S.Faris
Check this : Double-clicking a DWG file opens a new instance of AutoCAD
Before installing Autocad 2019 if you had a previous version of Autocad installed, most of the times it could be the "AutoCAD DWG Launcher" file association issue.
SALMANUL FARIS
this worked.  not sure how or why my SDI was set at (1), but changing that fixed the issue.  Another idea was to drag the dwg file onto the AutoCAD2019 desktop icon, but this opened two different program windows.
