How to open contours from Google Earth
Message 1 of 16
Hello;
I would like to take the topography of a region from Google Earth and model it in Autocad. Can anyone please  help me how to do it? Basically I have a geometry of a structure and I want place that structure on the place where it has been built and transform them to a fem software. Thank you.
Muhsin
Replies (15)
Message 2 of 16
imadHabash
Hi Muhsin,
>> I would like to take the topography of a region from Google Earth and model it in Autocad. <<
you can get it from SketchUp then export it as a drawing CAD file. >> Click <<
Imad Habash
Message 3 of 16
Dear Habash;
I have tried to use Sketch Up to create the terrain model. Unfortunately, Google Earth is supplying wrong data to Sketch Up for the location I am looking for. I have the kml file from Google Earth. How do I create contours from this file and make a 3D solid terrain? Thank you.
Muhsin
Message 4 of 16
Alfred.NESWADBA
AutoCAD (Vanilla) does not have functionality to create surfaces/contours.
If you need functionality like that I would recommend to look for AutoCAD Civil 3D >>>click<<<.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 5 of 16
john.vellek
Hi @Anonymous,
I see that you are visiting as a new member. Welcome to the Autodesk Community!
You might investigate PlexEarth from the Autodesk App Store to see how well it works with Google Earth.
John Vellek
Message 6 of 16
Dear Vellek,
Thank you for your perfect suggestion. I used Plex.earth and got the surface of terrain in 3D. My current problem is that how am I going to create a solid by giving a thickness below the surface?  Can you please help me out with that issue? Thank you
Muhsin
Message 7 of 16
john.vellek
Hi @Anonymous,
It would be helpful to see what you have in your file before I make a suggestion. Can you attach it or a portion of it to a post?
John Vellek
Message 8 of 16
Dear Vellek;
I appreciate your quick responses. The file is attached, Thank you.
Muhsin
Message 9 of 16
john.vellek
Hi Muhsin,
Perhaps using LOFT will get you a surface to start from.  Once you have that I believe you can give it a thickness.
I hope some other Community members will jump in and suggest better methods.
John Vellek
Message 10 of 16
Alfred.NESWADBA
HTH, - alfred -
Alfred NESWADBA
Message 11 of 16
Dear Alfred,
It seems you have found the exact solution that I want. Can you please tell me how you created the solid? Thank you.
Muhsin
Message 12 of 16
Alfred.NESWADBA
As I already mentioned, I used Civil 3D 😉
1) create surface from your contour lines
2) created a sold from surface with base elevation = 0.00
- alfred -
Alfred NESWADBA
Message 13 of 16
Dear @Alfred.NESWADBA and @john.vellek;
I am still working on the file that I have added in this topic. To be organized, I will request help as following,
*I would like to narrow the valley little bit to be compatible with the structure. Is that possible?
*I created the solid from contours using Autocad Architect ("Drape" operation), but it seems it is not being meshed in pre-processor that I am working on it. Do you have an idea about that issue?
Can you please help with those issues? Thank you
Muhsin.
Message 14 of 16
john.vellek
Hi @Anonymous,
Can you share your file again and indicate what you are trying to modify in the solid? are you trying to cut more in the valley or are you try to fill?
Have you tried SOLIDEDIT?
John Vellek
Message 15 of 16
Dear @john.vellek,
The file is attached. What I am trying to do is make the valley ( top-middle surface of the valley) little bit narrower to place a dam structure on. Meaning that, filling the surface without losing the actual pattern. The top surface consists of small triangle surfaces. Thank you.
Muhsin
Message 16 of 16
john.vellek
HI @Anonymous,
I think that you could perhaps use your contour lines to create new solids in the shape that you want and the presspull them to the correct heights.  Then you could Union or Subtract them from the main solid.
I do not use AutoCAD Civil 3D but I assume this type of procedure could be done much more efficiently with that vertical.
John Vellek
