AutoCAD Forum
How to offset line or figure with different distance
8 REPLIES 8
Message 1 of 9
785 Views, 8 Replies
Hello??
I'm in problem to draw offset in different distance like this example
This is just example
I hope to draw squares or lines over about 10,000 ...
So I need to know how to draw offset in different distance automatically..
I searched a lot.. but I can't find good solution to solve this.
My autocad version is 2014... So I can't use good apps that can be useful for offset..
Do you have any idea?
8 REPLIES 8
Message 2 of 9
Alfred.NESWADBA
why opening a new (3rd) thread for the same question, please stay in the thread where you already have suggestions, ideas, and a communication with others.
Creating a new thread only means more work for all of us ... you too.
Please stay and continue >>>here<<<
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
Message 3 of 9
in reply to: Alfred.NESWADBA
Sorry,,  I thought my post was deleted...
Message 4 of 9
Alfred.NESWADBA
Posts here are never deleted (as long as they match with general forum rules).
- alfred -
Alfred NESWADBA
Message 5 of 9
imadHabash
True ... and you won't find,especially after three or four posts that goes around the same issue .  So i suggest to mange well your time and start your drawing .  🙂
Imad Habash
Message 6 of 9
ВeekeeCZ
Well, it's not that difficult to program, 20-30 mins.
(vl-load-com)
(defun c:OffsetMultipleFile ( / *error* file lst line ss i o el+ el- ar+ ar- +/-)
  (defun *error* (errmsg)
    (if (not (wcmatch errmsg "Function cancelled,quit / exit abort,console break,end"))
      (princ (strcat "\nError: " errmsg)))
    (if file (close file))
    (princ))
  (if (setq file (open (strcat "c:\\Users\\OffsetMultipleFile.txt") "r"))  ;; se file name
    (while (setq line (read-line file))
      (setq lst (cons (atof line) lst))))
  (if (setq ss (ssget "_:L" '((0 . "LWPOLYLINE,CIRCLE,ARC"))))
    (repeat (setq i (sslength ss))
      (setq o (vlax-ename->vla-object (ssname ss (setq i (1- i)))))
      (if (vl-catch-all-error-p (setq el+ (vl-catch-all-apply 'vla-offset (list o (car lst)))))
	(setq el+ nil))
      (if (vl-catch-all-error-p (setq el- (vl-catch-all-apply 'vla-offset (list o (- (car lst))))))
	(setq el- nil))
      (if (setq +/- (cond ((and el+ (not el-))			+)
			  ((and (not el+) el-)			-)
			  ((not (and (not (vl-catch-all-error-p (setq ar+ (vl-catch-all-apply 'vla-get-area (list el+)))))
				     (not (vl-catch-all-error-p (setq ar- (vl-catch-all-apply 'vla-get-area (list el-)))))))
			   					nil)
			  ((> ar+ ar-)				+)
			  ((< ar+ ar-)   			-)
			  (T					nil)))
	(foreach d lst (vla-offset o (+/- d))))
      (vl-catch-all-apply 'vla-delete (list el+))
      (vl-catch-all-apply 'vla-delete (list el-))
  (princ)
File: offset from the original object per line.
Message 7 of 9
in reply to: ВeekeeCZ
Thanks for your reply..
Actually,, I solved this problem during weekend without that code you wrote.
I appreciate many comment here including you.
Thinking of other ways to solve this problem, I found it way using an coordinate..
I used copy function not offset..
I didn't know I can use copy function to make copies in the desired multi point that I commented as multiple offset.
It made my work easy
By the way,, How could I learn programming for autocad?
I heard this is called VBA... right?
Thank you for every one.
Message 8 of 9
ВeekeeCZ
It's a LISP. Probably the best place to start is HERE
Also, HELP  is a necessity.
But before learning to program it's important to know well the SW itself.
Message 9 of 9
Thank you for your reply.
I will try to learn LISP for next work.
AutoCAD Inside the Factory
