How to measure a block with field attributes?
vandenoosterkamp
vandenoosterkamp
When I try to measure a block that has field attributes the attributes disappear. In the attached drawing I have the original block with the working attributes but the other blocks do not show them anymore after the measure command. When I manually copy them to the desired place there is no problem.
I need around 4000 of them so I hope there is a way to solve this. I tried lisps as well that multi insert the blocks but with the same result.
j.palmeL29YX
Instead of the measure command I'd use the arraypath command. So you don't have the described problem.
If my reply solves your problem, click the "accept as solution" button. This can help others find solutions faster
Jürgen Palme
j.palmeL29YX
>>Here<< an example video how to use it.
HTH
Jürgen Palme
vandenoosterkamp
Thanks for the suggestion! The array however flattens everything and I need the Z coords to go up. Tried to fool acad by creating a new ucs in another drawing and copy paste but that didn't work
j.palmeL29YX
After arraying you must explode the array and update the fields (updatefield or regen command).
>>Example<<
Jürgen Palme
vandenoosterkamp
Yes, that does indeed the magic, also in 3d with adjusted ucs parallel to the 3d line.
Thank you very, VERY VERY much! 😄
