AutoCAD Forum
How to match properties on mtext with leaders
9 REPLIES 9
Message 1 of 10
3832 Views, 9 Replies
I did a test with one mtext size and color to another mtext size and color.  Both created separately using MTEXT command.
I did a Match Properties and one another and it works.
Now see attached file.  Different story on MTEXT made from a QLEADER command.
The Match Properties will not work.
WHY?
No wise guys.  How do you fix this so I can match properties on mtext attached to a leader.  I do not want to explode the mtext.
9 REPLIES 9
Message 2 of 10
Your text style and color is defined in your mleader style
Message 3 of 10
nestly2
Seems to work OK for me using (vanilla) AutoCAD2015
Are all the options checked in MATCHPROP settings?
If still no luck, upload a sample drawing with two different Leaders/Mleaders/Qleaders or whatever you're trying to match.
Message 4 of 10
pendean
let's see a DWG file with the problem.
Message 5 of 10
in reply to: nestly2
YES ALL CHECKED.
I'M BRINGING IN ANOTHER DRAWING (S) INTO A DRAWING WORKING FILE TRYING TO MATCH PROPERTIES WITH OTHER TEXT WITH LEADERS TO A NEW TEXT WITH LEADERS.  AND NOTHING.
Message 6 of 10
in reply to: pendean
I HADE TO SET MY MLEADER OR QLEADER SETTING AS ANNOTATION AS "NONE".  AND NOW IT WORKS.
THANSK
Message 7 of 10
nestly2
That makes sense.
Please mark your own post as being the solution.  Thanks
Message 8 of 10
To all Thanks.
This is the solution I found that fixed my problem.
I now can match properties with a multileader mtext with any text.
See attached.
Message 9 of 10
Thanks a lot.  I forgot about the mleaderstyle settings.  It's been at least 10 years since I ever looked at that for settings.
Message 10 of 10
mparammalJTPZM
thank you very much for the good information
Forma Design Contest
