- ALL vertices of a (2D) pline are located in the same 2D plane and have the same elevation.
- Multiple plines can be combined only if they are in the same 2D plane (coplanar).
- The elevation of a pline is relative to the plane in which it was originally drawn / created. With this in mind, even if the plines have the same elevation setting, the plines will only fillet if both are in the same reference plane or in parallel reference planes.
Since you are seeing a “not coplanar” message, you probably are working with one or more plines created from lines having different end point elevations relative to the current UCS setting.
From the picture- the blue and green plines were drawn as plines in parallel planes and will fillet.
The red pline, originally a line, was created using the PEDIT command. The vertical plane became the 2D X-Y plane for the resulting pline and the relative elevation (Z) direction is indicated by the red arrow.
The blue and green plines were drawn on parallel planes with the same reference UCS so they can easily be adjusted to the 2D plane. To fillet the red pline with the blue pline, reset the UCS (3-point method) where all points on each pline are in the same 2D plane, explode the plines and create one new pline before applying the fillet between segments.
