How to make lines in 3D intersect each other in AutoCAD
Mouhammad_mazzaz
Message 1 of 12
Mouhammad_mazzaz
Hi
please can u help me with this
I need to select two lines in the 3D and make them intersect to each other?
so can u help me with this ?! and how make a LSP file for this ?!
@Mouhammad_mazzaz
Topic Title has been changed for better findability by @Tiana_Y. Original: Intersection between two lines
Replies (11)
Message 2 of 12
imadHabash
to understand well your case ... would you please attach a screen image for your issue ?
Imad Habash
Message 3 of 12
Mouhammad_mazzaz
Yeah sure here u go thx for the replay
Line 1 and 2 not intersection cuz they are not in the same plan I think so what I need to do cuz I have so many like this I need an lsp so I can select the two-line shown in the  pic and make them intersect with each other
so that if I want to make trim or I need to snap to the intersection point I can.
https://www.screencast.com/t/vSOVuArZa
Message 4 of 12
imadHabash
if do you want to make all of your lines intersect and become at the same level plan , try to use FLATTEN command . if do you want more help you can attache here your CAD dwg file for testing .
Imad Habash
Message 5 of 12
Mouhammad_mazzaz
Let me try it and let you know
Message 6 of 12
Mouhammad_mazzaz
AHH That command makes my 3D canopy in 2D XD so it does the job but in 2D i want to do the same thing but in 3D  !
Message 7 of 12
imadHabash
Mohammad,
if you have a 3d solid CAD objects , you can NOT do that . again .. show us your 3d and tell us what exactly you want to do ?
Imad Habash
Message 8 of 12
Patchy
Different Z elevations how can they meet?
Like 2 jets in the sky you know ☺
Message 9 of 12
Mouhammad_mazzaz
Here you have attached the model also if u want to check it
this is a canopy I want to take this model and draw the steel beam in robot structural analysis
the problem is the curve line, not intersection each other
so in robot I can not snap to the intersection point
and in 3D I can not make that intersection
 so what I am looking, for now, to make these lines intersect each other
anyway I put the DXF in Revit and I make the model but it  takes me more time
so I want to know if there is any lsp or command it can do the job much easy
the Revit does the job cuz it automatically joins the analytical model so that what I was looking for.
https://www.screencast.com/t/QqVvCzzNd4ED
https://bit.ly/3fAJHEU
Message 10 of 12
Mouhammad_mazzaz
Exactly that what I need I need to make the z for the lines the same so they can intersect each other but it is hard without an auto lsp , cuz look at the dxf attached u will get my point if u can help me to do that tell me
Message 11 of 12
Patchy
In 3d, try SLICE the model at the elevation you want and snap to it.
Message 12 of 12
Kent1Cooper
@Mouhammad_mazzaz wrote:
Line 1 and 2 not intersection cuz they are not in the same plan ....  I need to snap to the intersection point ....
They don't need to actually intersect, nor be in the same plane.  You can use the APPARENT INTERSECTION Object-snap mode [APP abbreviation].  The returned point seems to be the apparent location on the more-recently-drawn of the two objects.
Kent Cooper, AIA
