How to make blocked objects visible in section/elevation view
vincentMBC6W
Observer Observer
vincentMBC6W
Observer
Observer
How can I make blocked objects visible in section/elevation view? I'm making a cabinet, and in the section view the drawer isn't visible because its being blocked by the side of the drawer box.
paullimapa
if you're in a layout vport and that side of the drawer box is a separate object on a separate layer then you can vplayer freeze that object and now see if the cabinet shows up
Paul Li
IT Specialist
@The Office
dmfrazier
How about using a Hidden visual style?
designN2EJF
Are you using viewports? if you use the 3DCLIP command, you can adjust the front and back lines to slice the objects exactly where you want. I'm sure you can find a YouTube video on how to use 3DCLIP, if it isn't intuitive enough on its own.
