How to make a 3d solid out of points or 3d poly
No aplicable
03-24-2016
01:29 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
My question is about Solid objects.
I have an output from Abaqus program and they are only coordinates which i get after calculation. these are the deformed rockmass coordinates.
Now i have to make a solid out of them and bring the new deformed rockmass as a solid to Abaqus program back.
in this autocad file which is attached
I have made different layers including different output forms
the frist and second layers includs a command which imports coordinates from text file as a 3d poly
3th and 4th are layers including just points
and the last one which is called test layer is just front and the back side of rockmass even in this layer if you use sweep commands it will make a solid but it doesn't connect the point in a proper way.
