Thanks for the reply socnandan.
I have Adobe Acrobat XI Pro, I tried testing it and was getting an error when it was generating. Is the Adobe Pro Extended different, or is there a plugin with it? I know some of the other programs in Autodesk can EXPORT to other formats that Bluebeam may handle to create a 3D PDF.
I just can't fathom sinking more money in, when I'm not even sure if some of these options will work or not.
I just wish Autodesk would come out with a solution especially a program as long standing as AutoCAD, that worked and had a top notch free, offline viewer to support, with all the bells and whistles that they keep putting in to A360. Give people the options.
I've looked at the DWFx briefly too, but it wasn't turning out as smoothly as I hoped.
https://360.autodesk.com/Viewer
(3DM, 3DS, ASM, CAM360, CATPART, CATPRODUCT, CGR, DAE, DLV3, DWF, DWFX, DWG*, DWT, EXP, F3D, FBX,
G, GBXML, IFC, IGE, IGES, IGS, IPT, JT, MODEL, NEU, NWC, NWD, OBJ, PRT, RCP, RVT**, SAB, SAT, SESSION,
SIM, SIM360, SKP, SLDASM, SLDPRT, SMB, SMT, STE, STEP, STL, STLA, STLB, STP, WIRE, X_B, X_T, XAS, XPR)
This seems to be one of the better solutions, I emailed someone to see if this could be available offline, they said no. But it handles 50 file types which is very impressive, which also tells me Autodesk is capable, I'd just like sometimes these options for scenario's other than online.
