How to link only the sheet number of a layout as a field in title block?
hussicharmssf
hussicharmssf
Hello everyone. I just want to know how I can link only the sheet number of a layout as a field in title block. For eg: If I have a layout named "A-001 PROPOSED SETTING OUT LAYOUT", I just want only the sheet number 'Á-001' to be added as a field in Title block. I know that using ctab in field we can link the layout name to a field, but it shows the name of the sheet also. But I want only the sheet number.Kindly post your suggestions. Thank you
0 Me gusta
Responder
517 Vistas
7 Respuestas
Respuestas (7)
pendean
Community Legend
Community Legend
There are lots of posts in these forums asking the same, here is one of many https://forums.autodesk.com/t5/autocad-forum/linking-fields-to-partial-layout-names/td-p/10555685
HTH
0 Me gusta
vinodkl
Hi @hussicharmssf
It's possible. In the title block type in the command "field" chose the field category select "other" and field names " diesel expression" and type this in diesel expression: $(substr,$(getvar,ctab),1,5)
and then click on ok. Hope this helps :cara_con_una_leve_sonrisa:
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
0 Me gusta
TomBeauford
Try Lee Mac's http://www.lee-mac.com/layoutfield.html
64bit AutoCAD Map & Civil 3D 2023
Architecture Engineering & Construction Collection
2023
Windows 10 Dell i7-12850HX 2.1 Ghz 12GB NVIDIA RTX A3000 12GB Graphics Adapter
0 Me gusta
hussicharmssf
THANK U SO MUCH
0 Me gusta
hussicharmssf
THANK YOU
0 Me gusta
hussicharmssf
THANK YOU
0 Me gusta
Washingtonn
You do not indicate if your sheet numbering will always have  a length of 5 characters?  how would revisions be indicated? 'A-001-01' ? If there will always be a blank space between the number and the rest of the sheet name, that may be a better way to go rather than changing the expression based on a variable length sheet number.
0 Me gusta
