How to keep panning after cursor reaches screen edge.
luis-pl
luis-pl
Back at the office I can pan the drawing past the screen edges, as if the screen was infinite (version 2013).
I can't do it at home, the panning stops when the cursor hits the edges, using version 2021.
How do I enable it?
Replies (21)
pendean
Community Legend
Community Legend
There is no edge in AutoCAD, 2021 or earlier: are you outside of a viewport bumping against that edge?
Or did someone decide to have fun with you by turning on LIMCHECK?
imadHabash
i suggest before panning , to use Zoom command >> type V then enter .
Command: Z ZOOM
Specify corner of window, enter a scale factor (nX or nXP), or
[All/Center/Dynamic/Extents/Previous/Scale/Window/Object] <real time>: v
Now try your Pan , any changes ?
Imad Habash
luis-pl
I dont know. It's a fairly old computer, running AC2013, but it works fine. The computer always had this infinite pan (and 3Dorbit) enabled, nobody really knows how to enable/disable. But it's useful and I like it, so I want to know how to enable it on other computers. This works in Modelspace.
Right now when I pan in my personal 2021 version, it will only pan until the cursor hits the edge, and no further, the same with 3Dorbit.
I have no idea what LIMCHECK is, it's set to 0, and I don't use grids.
luis-pl
Ok, I tried it. It remains the same.
I'm just trying to not be limited by limits of the screen when panning, so I can quickly pan big leaps without having to pan 3 or four times with the middle mouse button, same with 3Dorbit.
pendean
Community Legend
Community Legend
Does this happen in ALL files, or just this one DWG file?
Do you need to REGENALL by chance before proceeding?
There is no 2021 pan or zoom limit as you are describing it that I can see in the last month of using it.
imadHabash
how about trying Ctrl+scroll wheel mouse button to make panning and you can control the speed .
Imad Habash
luis-pl
@pendean It's for all files and there is no need for Regenall. I don't use that computer anymore, so I can't go back there and tests things again. I just know that the pan worked like that.
@imadHabash Control-Scroll remains the same, it stops orbiting once the cursos hits the screen limit.
Thank you for trying to help. I really don't
I found this thread, the guy seems to have the opposite problem, he wants to disable this infinite pan, but from there, I could not find any answer for myself (will try to contact the guy).
https://forums.autodesk.com/t5/autocad-forum/disable-off-screen-pan-realtime-wheelzoom/td-p/8324500
ChicagoLooper
This may seem like an obvious question but I'll ask anyway. How do you know the panning has stopped? What evidence is there that says, 'I have stopped panning, go to the forum and seek help.' Could it be you are panning and don't realize it? Just asking....
Chicagolooper
luis-pl
Wait, sorry, but what do you really mean?
It stops panning because i see it stop. It's like the cursor (mouse) is trapped inside a closed box, so when I begin panning, i click the scroll button, the cursor changes to a "grabbing hand", it grabs the screen, then I can "drag" the drawing around (pan), but when that hand (cursor) reaches the edge of autocad window, it hits the limit and it won't go further, hence, the panning stops.
So is this the normal thing, or is the normal thing to go beyond the screen limit and continue panning?
There is no info/support about this issue in the Autodesk Support page, neither do I find anything on the forums, so I'm seeking help myself.
pendean
Community Legend
Community Legend
You're not going to find anything online, your situation it weirdly unusual and unheard of in AutoCAD outside of what was stated so far.
Use this freebie to post a video of what is happening to you so we can see it: this tool records what you type and may be helpful https://knowledge.autodesk.com/search-result/caas/simplecontent/content/download-autodesk-screencast...
Otherwise I see a complete removal and reinstall of the application under a new Windows log-in in your near future, but who wants to do that.
TIA
cadffm
It stops not at the editor border, it stop at the program border? ,also if program window ist not maximized?
I guess it isn't an Autocad thing, but graphic card/setting.
It is for command: PAN and for mbuttonpan? (pressed mousewheel)
IF PAN works but the mouse-Pan not, it is a mouse issue?
Sorry, can not help.
Sebastian
ChicagoLooper
What is displayed on the command line when your panning hand can no longer pan like a panning hand can, understand?
Chicagolooper
ChicagoLooper
Have you tried this? Enter LIMIT on command line. Type in OFF=>ENTER.
Chicagolooper
luis-pl
So I tried reducing window size and panning again. The panning goes beyond Autocad Window, but it stops when I invisibly hit the Screen limits (Monitor). So maybe it is not an Autocad issue.
So I guess the norm is the infinite panning, which i'm having issues with.
LIMITS command turned OFF, but the problem persists.
I will try screencasting the problem tomorrow.
Thanks for the help.
cadffm
"So maybe it is not an Autocad issue."
Search in direction of Display/Desktop setting,
Autocad isn't involved.
Sebastian
eadamson79P6B
Community Visitor
Community Visitor
This absolutely IS an AutoCAD issue, related to Windows 11 and display resolutions. I have a similar issue but I want to turn the infinite panning off. I have two external monitors, one 1680x1050 vertical and one 1920x1080 horizontal. My laptop display is 2560x1600 and when I pan left or right to the point my mouse moves off the CAD display, the mouse is moved to a different relative position due to the pixel count difference. This causes my AutoCAD drawing to shift up or down depending on where I move off screen. This was not an issue with varying display resolutions using Windows 10 and AutoCAD 2016.
pendean
Community Legend
Community Legend
@eadamson79P6B wrote:
This absolutely IS an AutoCAD issue, related to Windows 11 and display resolutions....
Here are the ways to open a support case with Autodesk if you are on subscription to seek out Autodesk Support's help:
https://www.autodesk.com/support/account/manage/use/support#:~:text=com/plans.-,Contact%20support,-S...
If you wish to report a bug...
https://www.autodesk.com/company/contact-us/product-feedback
If you are using AutoCAD2022 at least ensure you have this addressed (restart your PC afterwards):
https://www.bleepingcomputer.com/news/microsoft/microsoft-lifts-windows-11-update-block-for-some-aut....
ChicagoLooper
Hi @eadamson79P6B
This sounds like a Windows Display Settings problem, not an AutoCAD issue.
Go to your Desktop=>Right click a 'Blank' area=>Display Settings
I have three monitors, so I see this.
<<Monitor #2 is on the left, monitor #1 is on the right, and monitor #3 is in the middle.>>
If I like,  I can change my mind and rearrange my Samsung monitor (Monitor #2) by moving  it from the left to the middle.
Then, in Windows Display Settings I'll drag monitor #2 and drop it between #3 and #1. The drag-and-drop will make the Windows Display Settings consistent with the actual arrangement on my desk.
In the end, the Display Settings shows Mon #3 has been moved to the far left and Mon #2 is now in the middle.
The new Display Settings allows my mouse to have new 'extents' which means it'll move to the far left edge of Monitor #3, but no further, and to the far right edge of Monitor #1, but no further. It's important to rearrange the monitors in Display Settings, otherwise the cursor will be whacky.
Chicagolooper
Brock_Olly
I have the same issue now too, not sure since when, but I'm on version 2025.1.2
I used to be able to pan a viewport past monitor 'edge' into infinity.
I remember I had this issue a few years back and I'm pretty sure it was a system variable that fixed it, not sure which one though.
This issue is for all panning, in model space and in viewport/paper space
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
