How to join lines
How to join lines
How to join lines
The white line is join and the yellow line is not join.
How to join the yellow line
richardC38RY
The end points do not meet, this often happens when you import from a PDF or drawing from another software.
The easiest way is to select one of the lines and the grips will show up as a blue square on the endpoint, click on the grip then click on the endpoint of the other line. This will snap the endpoint of the line onto the endpoint of the other line and then you will be able to join it.
ennujozlagam
click the other line when you saw the blue box drag to another points and type PEDIT > select the two lines > then JOIN they will become one line. thanks.
imadHabash
You have to do it manually !! by a proper osnap or using grips you can meet you lines end points . click on below image
Imad Habash
j.palmeL29YX
If you have a lot of such gaps and don't want to correct each one by one you cn also try >>this way<<:
- draw a line or arc to get a "closed" area
- start the hatch command, set an appropriate tolerance and activate "Retain boundary".
- if done you can delete the hatch, a closed polyline will remain.
- check the result
- remove the first drawn additional line/arc ... there are some ways to do it.
Be aware, sometimes you will not achive the needed result, therefore check carefully what you got.
HTH
Jürgen Palme
