Anuncios
How to inverse break?
No aplicable
For example I have simple rectangle. (I am using AutoCAD 2016)
I need to get figure like on picture 1.
I press "break", choose first point, choose second point as on picture 2.
Unfortunately I get thing as on picture 3.
What am I doing wrong? And it's strange that if I do the same procedure to right edge I get what I need, but I need to do it with left edge (without using mirroring).
0 Me gusta
Responder
Soluciones aceptadas (1)
1.069 Vistas
2 Respuestas
Respuestas (2)
Alfred.NESWADBA
Solución aceptada
a polyline has a direction (as you have drawn it), so it makes a difference if your polyline was drawn clockwise or counterclockwise.
In your case there is a better solution available (whenever you want to delete a complete segment of a polyline):
  • Hold the <CTRL> key and then click onto the segment you want to delete (this selects only that segment of the polyline)
  • Press <DEL> to erase it
  • (in that case the direction of the polyline is irrelevant)
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2025
(not an Autodesk consultant)
No aplicable
yeah! Both of your hints (about clockwise and about <CTRL>) work perfectly even if rectangle was inserted as rectangle (not drawn using polyline)
0 Me gusta
