How to intersect Lines with surface
10:10 AM
I am using BricsCAD, because I have Linux. My task was in macro draw about 20 000 lines to intersect the surface (in reality there are two surfaces of the solid plate). My task is done on the half. I have the lines, but on surface are no intersections (doesn't matter points or intersection segments of lines). My colleague has AutoDesk. It is possible to finish this work to create the intersections of the lines and surface some easy manner (i.e. not to click on the each point of intersection manually)?
There is original question from BricsCAD forum. In attachement is inner surface and one line intersecting it.
https://www.bricsys.com/common/support/forumthread.jsp?id=31483
Thank You forward for answer,
Hariprasad
