[HOW to] Insert Text in Coordinates
No aplicable
I have data like below
Coordinates X, Y value and some remarks
X        Y        TEXT
100    150    TRENCH START
150    150    DUCT BANK START
200    150   DUCT BANK END
300    150   TRENCH END
I want to Import above text value in respective coordinates in AutoCAD.
Please suggest me some good lisp or idea to finish my work.
I have more than 1000 data to enter like above.
please help me out.
MK
0 Me gusta
Responder
Soluciones aceptadas (1)
15.967 Vistas
16 Respuestas
Respuestas (16)
Jonathan3891
You could create a script file like this.
point
100,150
text
100,150
TRENCH START
point
150,150
text
150,150
DUCT BANK START
point
200,150
text
200,150
DUCT BANK END
point
300,150
text
300,150
TRENCH END
end
Jonathan Norton
Blog | Linkedin
No aplicable
Hi Jonathan Norton,
Thanks for for your reply.
Actually in my company script file is locked.
like I cannot save file extn as *.scr
Emoticono frustrado
Please give some other option if any
MK
0 Me gusta
Alfred.NESWADBA
>> Actually in my company script file is locked. like I cannot save file extn as *.scr
Ask them to let you save it, just not execute it (execute from operating system).
As alternative: when you have the file created, you can also copy & paste the content of the script into the command-line of AutoCAD. It's the same as starting the SCR with command _SCRIPT.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
0 Me gusta
No aplicable
Hi  Alfred ,
Thanks for your reply.
I already tried the same , IT could not help me in this.
As you said I tried this,
copied the content and pasted but text did not placed, instead it was asking to enter text - SEE ATTACHED FILE
MK
0 Me gusta
Alfred.NESWADBA
ohh, you are right, didn't think about TEXT, sorry!
Do you have AutoCAD or AutOCAD LT? In first case you can use LISP to place the text instead of direct input as command, sample:
(command "_TEXT" "1,1" "2" "0" "This is my Text")
- alfred -
Alfred NESWADBA
0 Me gusta
No aplicable
Hi Alfred,
I am using Autocad 2015 (full version)
Can you write and give sample LISP?
I do not know how to write lisp program
MK
0 Me gusta
Alfred.NESWADBA
Solución aceptada
I wrote you one line as sample in my previous message, you just need to use this line with your text, textsize, position and rotation:
whereas;
  • "_TEXT" is the command you call from lisp (so it does not wait with the cursor in the screenarea)
  • "1,1" is the position
  • "2" is the textsize
  • "0" is the rotation
  • "this is my text" is the content you want to write
So the first two text objects from your sample then looks like that (well, not nowing text height and rotation):
(command "_TEXT" "100,150" "2" "0" "TRENCH START")
(command "_TEXT" "150,150" "2" "0" "DUCT BANK START")
HTH, alfred -
Alfred NESWADBA
No aplicable
Hi alfred
that worked...!!!!
Emoticono muy feliz
Emoticono muy feliz
Emoticono muy feliz
Emoticono muy feliz
Thanks lot, 1000 data in one go...
MK
0 Me gusta
anders.haukeland
Prefect!
I have been looking a method like this for quite some time :cara_que_ríe_con_la_boca_abierta_y_los_ojos_sonrientes:
Do you know if similar approach is possible for multi line text as well?
0 Me gusta
No aplicable
As advised the lisp file has been created.
What should be the command to run the lisp in auto cad?
0 Me gusta
No aplicable
Dear Karthik
May I have the LISP file you created or some sample lisp in this regards? Please send it to kbg1973@gmail.com
0 Me gusta
No aplicable
Picture1.jpgCreated LISP like this. Is it OK? or Please advise.
0 Me gusta
Alfred.NESWADBA
You can simply copy & paste these lines into the command-line area of AutoCAD.
- alfred -
Alfred NESWADBA
0 Me gusta
hannes.randhahn
Hey there,
I just saw this problem and i wonder if this would be possible for in- and output?
I want to extract coordinates from lines and re-enter some text at these positions.
Could this be done with excel as well?
example Ouput: Line1, x=10,y=20,z=0 [via Dataextract]
Input: Text"Line1" at x,y,z
Would this be possible through Lisp, without the in-between command elements?
The whole idea would be to output Data > manipulate in excel and input back again into plan drawings as text.
Thanks for any help in advance.
0 Me gusta
Alfred.NESWADBA
Hi yes, if you want it using LISP then >>>this forum<<< would be the best to ask.
- alfred -
Alfred NESWADBA
0 Me gusta
omar_zdn
Community Visitor
Community Visitor
0 Me gusta
