The first photo shows a larger menu text which is fine. The second photo shows the text when I go to input dimensions which comes out small . Is there a way to increase the small text?
Solved by pendean. Go to Solution.
you can always use your scroll mouse while you're in dimension text edit mode and zoom in closer
