How to imprint an image on the surface of a solid?
efaruque
Observer Observer
efaruque
Observer
Observer
I need to imprint an image/logo on the curved surface of a solid. Is it possible in AutoCAD?
efaruque
Observer
Observer
Thanks a lot for your reply.
I asked whether there is a way to imprint an image, jpg or png on the surface of a solid. All these are geometric bjects rather than an image.
pendean
Community Legend
Community Legend
There is no ability in the program to do that with Raster images: they are flat and 2D, so you need to find a workaround with a solid of the same size then with on placement of your image. But them will remain separate objects.
Maybe you need to use your image as a material on that object instead? That you can do in AutoCAD
https://forums.autodesk.com/t5/autocad-forum/put-an-image-on-a-solid/m-p/10793326/highlight/true#M10...
