How to hide this input bar from command line?
Mahmoud-elsayed145
Mahmoud-elsayed145
Valentin_CAD
Hello Mahmoud-elsayed145,
Interesting issue!
  • Try to close and restore (CTRL+9) the Command line or the CUI (see image).
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
ian.mag
Hi @Mahmoud-elsayed145
I think the suggestion put forthe by @Valentin_CAD should work fine.
Should it persist, you can always Reset to Default as follows:-
Start menu> All programs> Autodesk> AutoCAD (your version)> Reset to Default
You'll only lose your custom settings and you plot sytles but you can always customize onece more.
