how to get the toolbar back
Message 1 of 8
ello,
I accidentally hide the toolbar.. i tried to get it back but i made it worse by hiding actually everything what is normally at the top my screen.. does someone know how i get this back because i use the toolbar all the time and dont really like using shortcuts because i dont know all the names from the things i use.. see photo thanks!!
Replies (7)
Message 2 of 8
Alfred.NESWADBA
first I would try is to use the workspace-icon in your status bar (lower-right, gear-like symbol) and activate another workspace, then change back to the workspace you had before.
If that does not work then try
if you meant ribbon ==> command _RIBBON
if you meant toolbar ==> command _TOOLBAR .. and there you might need to know toolbar names like "Standard" or "Layer" and enable them
HTH, - alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 3 of 8
Yes i ment ribbon. It was at first at the top but now i can only get it to the left or right side. And no opening a new template does not help.
Message 4 of 8
i was trying to get it back and yes i ment ribbon. but i can only put it to the left or the right side. how to i set the ribbon on the top. command "addhorizontalribbon"does nothing..
Message 5 of 8
Alfred.NESWADBA
Have you tried my first suggestion to change the worksspace?
Move your mouse to the position marked in the following image, click and hold the mouse to move the ribbon and put it anywhere else.
If it can't be moved then enter command LOCKUI into the command-line and set it to 0 in case your UI is locked.
- alfred -
Alfred NESWADBA
Message 6 of 8
that was easier then i thought.. i worked but in order to see everything i have to hover over the ribbon. before i did what i did i could see actually everything instead of first hoovering over the ribbon. do you know what i mean..? and do you know how i can get that back to normal..? thanks!! see image
Message 7 of 8
Alfred.NESWADBA
please click that small icon as often as needed to get the state of Ribbons shown as you like to have them.
- alfred -
Alfred NESWADBA
Message 8 of 8
thank you. my problems are fixed. thanks for your time!!
