How to get green dashed lines longer?
Hi, for some reason I think I've changed my snapping distance for drawing lines. So when my mouse hovers over a line, the green dashed predictive line of where the lines will intersect is much shorter. Is there a way to get the predicted dashed line to be less senstive and go across a bigger distance?
Thanks everyone!
a.blackMV4H7
Have you tried adjusting the Auto Track Settings within Options?
Go to Options, then Drafting tab. Check the Auto Track Settings (Top RH corner) item 'Display full-screen tracking vector'.
imadHabash
You may see Auto Track settings from  OPTIONS command >> Drafting tab .
Imad Habash
Thanks so much, I think that sorted it!
Thank you so much, I think that sorted it : )
