how to get ESC key to save text when using single line text (DTEXT)
jetted4
Message 1 of 26
jetted4
Most everything in Autocad saves what you did if you hit the escape key. but when I get to entering single line text, I keep loosing my content everytime since my personal automatic response is to hit the escape key after most every command.
Is there some way to change the setting so that it will save, not erase, what I typed when i hit the ESC key?
Replies (25)
Message 21 of 26
jetted4
Not dire  🙂
Just frustrating.  Thanks  🙂
Message 22 of 26
Kent1Cooper
Something is occurring to me that may be [part of?] a reason that it works as it does.  Suppose you are in the middle of typing in the content in a TEXT command, and for whatever reason you decide "never mind -- forget the whole thing."  As it is now, you hit ESCape, and the whole thing is forgotten.  If it worked as you want, you would presumably hit ESCape but your TEXT would be completed as it was up to that point, you would have added something to the drawing, and you would need to Undo to get rid of it.  There would [I think] be no "forget the whole thing" option at all, unless they were to program in something like Shift+ESCape to do that.
In comparison to how LINE works [& PLINE], with ESCape leaving in place where you are so far:  If TEXT worked as you describe, would the corollary in LINE be that when you hit ESCape, it finishes by drawing a final Line to your current cursor location before exiting?  Is that "where you are" while drawing Lines, in an analagous way to "where you are" in typing Text content that you would want left there?
There is something different about the nature of picking points in a LINE command, each of which actually completes something, from the nature of typing the individual characters in TEXT content, none of which does, at least not in the same way.  So it's at least arguable that the way ESCape operates is justifiably different between the two.  But at least it might be nice if they could make it an option to choose which way you want it to work in TEXT.
Kent Cooper, AIA
Message 23 of 26
jetted4
hmm...
With the Line and Pline as comparisons, I haven't really finished drawing a segment until I place the next point (as you noted in the latter part of your comment) and at that stage, hitting ESC retains it.  If you are hanging in midair, not having decided where to place another point, and hitting Esc eliminates the hanging segment, that makes sense since you didn't actually draw it.
With the text, I may have fully finished typing in the text reference that I was adding to my drawing, but an extra action (one that is contrary to how text entries work in other settings) of pressing Enter (or clicking elsewhere) is required in order to not lose what I typed.
For the "never mind, don't need it" option, it is pretty quick to just Ctrl-Z to undo, so between having Esc take that approach (as it does now for DText) vs retaining my text, I'd vote to retaining my text.
Thanks for the thoughts  🙂
Message 24 of 26
jact363
Community Visitor
Community Visitor
i WAS HIGHLY WITH MY DTEXT DISSAPEARING i FOUND THAT A PREVIOUS RESPONSE SOLVED MY PROBLEM.  THE TEXT SIZE WAS 3/16" i INCREASED IT  1'ND TO MY SUPPRISE IT WAS STILL THERE WHEATHER i USED ESCAPE OR ENTER.
Message 25 of 26
jact363
Community Visitor
Community Visitor
MY DTEXT WAS DISSAPEARING WITH ENTER OR ESCAPE,I FOUND FROM AN EARLIER POST THAT IT WASN'T DISSAPPEARING AT ALL IT WAS JUST TOO SMALL TO SEE. CHANGED TEXT HEIGHT FROM 3/16" TO 12" .NOW IT SAYS WHERE i PUT IT.
JTerry
Message 26 of 26
jact363
Community Visitor
Community Visitor
MY problem was solved by increasing text size from 3/165" to 1'.  Now I san see what I typed
J Terry
