Anuncios
How to flatshot 3D to 2.5D with dimensions
No aplicable
How to flatshot 3D to 2.5D with dimensions.
The 3D model is
I convert it to 2.5D with flatshot command and have hidden line in obscure line.
How to convert the dimensions to 2.5D.
0 Me gusta
Responder
Soluciones aceptadas (1)
1.803 Vistas
6 Respuestas
Respuestas (6)
Alfred.NESWADBA
dimensions can't be used with _FLATSHOT, why is the needed?
The workaround which I could think of is to plot to PDF (or DXB) and then attach or insert the PDF ... but in that case dimensions are not any more dimensions (I guess that's why _FLATSHOT can't work with them).
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2025
(not an Autodesk consultant)
0 Me gusta
No aplicable
I want the obscure line is hidden line and plot to PDF with dimensions.
0 Me gusta
Alfred.NESWADBA
Solución aceptada
Then change to a visual style (I used "Hidden" in the screenshot) that has "Occluded Edges" set to visible and run _PLOT then.
Drawing and PDF attached.
- alfred -
Alfred NESWADBA
0 Me gusta
No aplicable
If I change to Hidden visual style,the line quality very low(See the PDF)
0 Me gusta
Alfred.NESWADBA
have you tried to plot my drawing?
Compare your dwg/your visual style settings with my ones.
- alfred -
Alfred NESWADBA
0 Me gusta
No aplicable
Thank you.
0 Me gusta
