how to fixed non-plot xref layers for all drawing files in just one command?
gladim
gladim
Who has a knowledge on how to do it in just one command. It's like I will select one folder where all drawings are located then, type a command that will change xref layers currently in a "non-plot" into a plot visible layer. Thanks in advance!
Gerry
Never heard/know before for this command. But for me usually using layer properties manager, from there i can short by on/off, freeze, lock, color, linetype etc.
gladim
Thanks for the idea Ahmad. I sure hope somebody has an LISP that could do it.
Sahay_R
In Layer Properties - select all layers you want to not plot, click on the little printer so that it's X'ed out. That's as short and simple as it can get.
Either that, or move objects that you don't want to print to layer DEFPOINTS.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
gladim
I have done this already. But, it's not the solution I am looking, It's got to be a LISP that get's it done in one command for a large number of details. (not one at a time.)
Ask over here
You could use AutoCAD script routines to accomplish what you are looking for. I have added two script routines below for you to test out. We supply Multi-Batch but you can use these in any batch program.
To change the Plot setting for all layers you can use the script routine below. The * character selects all layers.
;;Start of Routine
-layer
p
p
qsave
;;End of Routine
To only change the Plot setting for Xref layers you can use this script. The | character is associated with Xref layers so by using *|* you can select the layers associated with Xref’s
;;Start of Routine
-layer
p
p
qsave
;;End of Routine
Now it is a simple matter of selecting the drawings, assigning the routine and watching all the drawings been processed.
Patrick
http://www.multi-batch.com/
For your entire batch processing needs
