How to find the tangency without tan/tan/radius
jcasey7460
jcasey7460
I'm going through a chapter in my textbook called geometric construction. It's been helpful so far. I've discovered I can find many values that aren't given by using these geometry techniques.
Question...how would you find the tangency of the two yellow circles, given their radius, using geometric construction (without using tan/tan/radius)?
Screenshot and .dwg attached....Thanks to everyone for help with the past drawings. I do realize this is probably technical drawing 101...I"m slowly getting better at this, at least I think I am.... 😅
Kent1Cooper
Offset the two Circles that the yellow ones are to be tangent to, by the radius of each yellow one, and an intersection of the Offset results will be the center of a yellow Circle.
Kent Cooper, AIA
imadHabash
as seen below you can by Parametric GCTANGENT command get such a service that may help . depending on your available data you can decide which Parametric constrain you will need .
Imad Habash
jcasey7460
OMG, that's perfect! Thank you @Kent1Cooper ....and to think I struggle with this for hours yesterday, makes me feel really dumb. LOL I also understand why that's done for the most part...this is fun but it can tough when you get stuck like that..it makes perfect sense why you did that though...very logical. Thanks again!
jcasey7460
Nice, that is interesting. We are just starting the Parametric commands this week so this is great that you've mentioned that. I will check this out today. Thank you!
