>> Autocad has a habit of sometimes creating doubles of objects
Which commands are you referring to?
I never had issues with AutoCAD that AutoCAD creates doubled objects, in most cases it's the user starting commands which by default create copies or doubles.
AutoCAD itself does not create double lines when you draw just one line 😉
>> Is there a way to find overlapping spaces
Can you please let us know what you mean by "overlapping spaces"? Please upload a dwg file that describes such a situation.
It could also be helpful to know which version and type of AutoCAD you are using, e.g. Map3D and Civil3D has a command _MAPCLEAN which can do a lot more with double objects compared to the standard AutoCAD command _OVERKILL.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ...
blog.ish-solutions.at ...
LinkedIn ...
CDay 2026------------------------------------------------------------------------------------
(not an Autodesk consultant)
