Anuncios
How to find out the total number of objects in a drawing
No aplicable
I have some drawings that have a lot of hatching and the large number of objects and file size is causing problems when I insert it into another program. Some of the hatches were generating 16,000 objects in a 3" x 12" drawing.
I would like to find out the total number of objects in a drawing to track my progress at reducing the number of objects and file size.
0 Me gusta
Responder
666 Vistas
3 Respuestas
Respuestas (3)
cadffm
When all Layers are thawed, command SELECT, option ALL,
You will see the counting of ALL top-level objects in your DWG (all spaces)
Or for only the current space also possible:
When the number of objects fewer then your PROPOBJLIMIT (max.32767)  you can see the count in your properties palette (CTRL+1)
If there are more objecs and you have full version of AutoCAD, use this "command" (sslength(ssget "_X")).
In both versions, Full&LT also possible after selection by CTRL+A: Start command MOVE or Copy or similar,
you can cancel the command then, the answer is written in commandline [F2]
______
Sebastian
ian.mag
Hey @Anonymous,
To add on what @cadffm has mentioned, you may use the quick select QSELECT command, and select the object type desired based on the various properties that the object has.
0 Me gusta
No aplicable
Thanks everybody for the help. I had so many problems plotting the drawings as pdf's I had to try something
else. I exported them as .bmp's and the resulting images were easy to work with.
0 Me gusta
