How to FIND and REPLACE mtext fractions like 2-1/2" and change to 3"
EBSPEAMD
Message 1 of 12
EBSPEAMD
Hello all.
Hoping someone can help.  I need to swap a bunch of 2-1/2" in mtext to 3" and I would rather do it via the search function than trying to find every single one and changing it manually.  Problem is, AutoCAD doesn't seem to do that.  I've been searching online and found the superstr.lsp but I can't get it to work.  All I get is the following error -"Updated 0 text string; error: AutoCAD variable setting rejected: "OSMODE" nil"
Not sure if there is a fix for this or just to do it the hard way.  Any help would be greatly appreciated.
Thanks!
Replies (11)
Message 2 of 12
pendean
Community Legend
Community Legend
Message 3 of 12
EBSPEAMD
Hi pendean
Message 4 of 12
imadHabash
Find and replace work fine !!! check your search option as shown below .
Imad Habash
Message 5 of 12
EBSPEAMD
That doesn't work on mine.  I'm using 2019 - just for point of reference.
All I get is it saying it can't find it the 2 1/2" is in Mtext and it looks like this:
Message 6 of 12
Kent1Cooper
@EBSPEAMD wrote:
....  I need to swap a bunch of 2-1/2" in mtext to 3" ....
Are the ones with fractions actually shown in that format [in which case FIND should work as @imadHabash illustrated]?  Or are they stacked?  [Crossed in the mail -- answered by preceding Message.]
Kent Cooper, AIA
Message 7 of 12
imadHabash
i think that first you have to Remove All formatting from your mtext . see  Contents in your image
Imad Habash
Message 8 of 12
EBSPEAMD
So in order to replace the text, I need to remove the formatting when I'm trying to do the find and replace drawing-wide?  I would have to go through and individually select the mtext to do that - I don't want to remove the formatting on my other stacked fractions.
Somehow the manual way seems easier than that.
Message 9 of 12
Kent1Cooper
Only the fraction-stacking formatting.  Try StackStyleForce.lsp with its SSF command, available >here<.  Choose the None option, and all stacked fractions [throughout the drawing]  will be un-stacked.  Then FIND can be used to do your replacement.  If you like, you can then use SSF again, selecting a different stack style, to re-stack all other fractions.  Read the comments -- it's pretty comprehensive [applies the chosen stacking style to not only all Mtext content but also all Dimension Styles].
Kent Cooper, AIA
Message 10 of 12
EBSPEAMD
@Kent1Cooper
I get this error "Stacking style [Horizontal/Diagonal/None/Tolerance] <N>: N; error: bad argument value: positive 0"
Message 11 of 12
Kent1Cooper
@EBSPEAMD wrote:
I get this error "Stacking style [Horizontal/Diagonal/None/Tolerance] <N>: N; error: bad argument value: positive 0" ....
I'm not sure where that could be coming from.  I was going to ask whether there are no  objects containing stacked fractions, but the message is different in that case, and does not cause an error.  It was written under Acad2004, but still works for me in 2019.  Are you using a newer version than that, in which case there might possibly be something that now works differently?  [My first guess would be a difference in the DIMFRAC System Variable values, but they appear to still be the same.]
BUT I was partially wrong earlier, anyway, so it may be only a partial solution for you even if it works -- I'm afraid it doesn't  re-stack fractions in Mtext or Dimension override text content.  It only assigns the chosen stack style to all Dimension Style definitions.  I had forgotten that its work in Mtext & override Dimension text depends on finding stacking-type control codes, so once they've been removed, it won't recognize those Mtext objects as containing fractions that should be stacked.  I'll have to think about whether that can be incorporated, since it seems useful, and essential to what you want to do. [EDIT:  In fact, I find I have a copy with a slightly different name, for working on it, in which I had already raised the question.  The first complication is in finding the stacking characters and differentiating those that are parts of fractions from those that are not, but even after that, there are other challenges in putting the code characters in, when there could be others around.]
Kent Cooper, AIA
Message 12 of 12
EBSPEAMD
So I've hit the proverbial cluster nugget.  I appreciate the attempt @Kent1Cooper.  I definitely don't want to unstack all of my fractions and then have to manually fix them all.
