How to fill/hatch 3D objects?
Hey all,
Have built a 3D model of a covered timber bridge (Geiger's Covered Bridge in Lehigh County, PA).
I'm not sure how to fill/hatch these objects. I do know I want the fill to make the 3D wireframe actually solid (so I'm not able to see through a timber beam for instance).
How do I do this? How do I assign color?
Is there also a way to create a light source in the model? Or give the bridge the appearance of being affected by light?
Thanks!
natasha.l
Hello @Anonymous,
You can type or use the tool palette for the "SOLIDEDIT" commands to color faces or apply material to faces.
Please "Accept Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
imadHabash
HI,
since you work with a 3D model , suggest to change your Visual Style .
Imad Habash
