How to enable layout tabs left and right scroll arrows, instead of new default?
Jonathan.Gray68UQW
Message 1 of 24
Jonathan.Gray68UQW
Hey all,
How can I restore the layout tab left and right scroll option instead of the new down arrow option as shown in the attached image? I liked the way it use to be better.
Replies (23)
Message 21 of 24
cadffm
@cschnarrneed to upload the file "gotab.dcl" too.
@dprice75  or create your own one
which_tab : dialog {
  label = "Go tab";
     spacer;
     : list_box {
      allow_accept=true;
      height=20;
      key="tab_lst";
      label="Layouts:";
      multiple_select=false;
   spacer;
  : row
     : button {
      fixed_width=true;
      width=13;
      key="accept";
      is_default=true;
      label= "Go to..";
    : button {
      fixed_width=true;
      width=13;
      is_cancel=true;
      key="cancel";
      label= "Cancel";
  : text_part
    key="error";
    label="";
, name the file gotab.dcl, make sure it is stored in a support folder
Sebastian
Message 22 of 24
dprice75
Now it works!  Thank you so much.  This is a nice little program.
Message 23 of 24
dansielda
Community Visitor
Community Visitor
can you make a tutorial? tnx
Message 24 of 24
cadffm
Copy the code (mark & ctrl+c)
Paste (ctrl+v) it in EDITOR/NOTEPAD
and
"name the file gotab.dcl, make sure it is stored in a support folder"
You can check for current supportfilepathes, or add another folder here:
Command OPTIONS, tab FILES, first node
Sebastian
