AutoCAD Forum
How to draw this oval shape?
5 REPLIES 5
2416 Views, 5 Replies
I've been given both of these as a homework from a uni professor who doesn't explain anything and isn't responding to emails. I have no idea on how to draw the main oval shape thing of both of these and English isn't my first language so I cannot name or explain it. Any help, especially a video on how to draw it would be appreciated.
5 REPLIES 5
Use EL command for that
Is an ellipse going to work for this? Any idea on arguments to throw at the function?
vinodkl
See the screencast.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Moshe-A
@Anonymous  hi,
start with the center lines than add all central circles. at the left side add the 2 full circles (yes for the outer one also)
your challenge is this:
1. to draw the left outer tangent lines (up & down). well this is very easy to do with osnap tangent (are you already familiar with osnaps?)
2. cut off the redundant lines (with trim command)
3. do a mirror for the right side
4. you are done 😀
Moshe
in reply to: vinodkl
Thanks a lot!
Forma Design Contest
