How to draw an arc at a certain radius and length?
russel
Message 1 of 10
russel
how do you draw an arc at a certain length and radius?
for example I want to draw an arc at 149'-9" long at an 2793.25' radius.
Replies (9)
Message 2 of 10
Kent1Cooper
I don't think you can do that directly with standard AutoCAD Arc-command options.  I think you'll need to use a routine such as [just one example] ArcLength.lsp, available here.
Or, in two steps, you can draw an Arc at the desired radius, of any length [or a Circle, and Break part of it out to make an Arc], and use LENGTHEN and its Total option to make it the length you want.
Kent Cooper, AIA
Message 3 of 10
TheCADnoob
@Kent1Cooper solution of lengthening you arc sounds best, but i created this video so i figured id share it any way.
The formula i used is
c=(360∙L)/(2∙π∙r)
CADnoob
Message 4 of 10
russel
that helps thanks.  a little more work than I wanted to do but still works.
would be great if they had a feature where you could type in the radius you wanted along with the length you wanted and hit enter.
Message 5 of 10
TheCADnoob
@Kent1Cooper's suggestion is much easier
CADnoob
Message 6 of 10
russel
that way is even easier, thanks for the help.
Message 7 of 10
davidUB2V2
Community Visitor
Community Visitor
Thank you for the help with this topic.
Message 8 of 10
great answer (even if not yours)!
thanks for the instructional video
Message 9 of 10
Charles_Shade
Message 10 of 10
Des_R-Turner
Thank you. LENGTHEN and Total worked great for what I needed.
