AutoCAD Forum
How to draw a annotation line like this?
3 REPLIES 3
587 Views, 3 Replies
The attached picture is the problem I have, I just forget hot to draw a line with leader in both side with text. (the one with TJI 16" OC TYP)
3 REPLIES 3
ChicagoLooper
in reply to: 123889158
Use DIMLINEAR and draw the dimension. Next, double-click on the number (the dim value) and over-write this value with the text that you want to display. In your case: TJI @ 16" O.C. TYP.
Chicagolooper
in reply to: ChicagoLooper
I just added a leader for my leader, but ur solution is also good.
Kent1Cooper
@ChicagoLooper wrote:
... draw the dimension. Next, double-click on the number (the dim value) and over-write this value ....
Or, more simply, draw the dimension, but before giving it the dimension-line location, use its Text option and spell out what you want it to say instead of the measured distance.
Kent Cooper, AIA
Technology Administrators
