How to do auto-numbering in CAD layout?
m.virdi74J8L
m.virdi74J8L
Community Visitor
Community Visitor
Gday guys,
I have nearly 200 sheets for putting up a drawing number manually. The number in my template looks like 1427-401 in first sheet, then 1427-402 in second & 1427-403 so on.....
Can you please guide me if i can do any automatic thing so that i don't have to change all the numbers manually.
Also, I couldn't understand how the field or Tcount command works. Can someone please help me on this.
Thanks in advance
j.bongers
Try to work through a document that you can find on the internet that is called "Sheets Happen"
https://forums.autodesk.com/autodesk/attachments/autodesk/66/396167/1/Sheets_Happen.pdf
I have just recently worked through it and it is already transforming my workflow.
J.Bongers
***THE POST HAS BEEN EDITED FOR CLARITY***
maratovich
Add an example of your file.
Software development
Automatic creation layouts and viewport. Batch printing drawings from model.
www.kdmsoft.net
