How to display Attribute Tags
I have a drawing from another consultant which shows not only the attribute values next to the block, but is also showing the attribute tag.
I want to do this in my drawing but I cannot find the command or system variable to turn the TAGS on as well.
Any assistance much appreciated.
Attribute tag : Attribute value
jayhar
Attributes do not show for blocks in AutoCAD click here
Please upload AutoCAD 2013 format, delete all layout
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly. If your issue persists,
Please give me a bit more detail on this issue so we can continue to work towards getting this solved.
Thanks You
Jayhar.M.J
Helpful Links: Prepare your computer for download |  Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
cadffm
Thats impossible. What you see is not the attribut-tag, it is a stupid Text,MText or constant Attributdefinition.
Use Bedit and check how the block was built.
Sebastian
KLUG-TICIANO
Mattok
Hi.
I will send to you in this weekend, using vba.
OK?
In many case I use this.
Bye.
Ticiano
j_weber
Do you mean like in my screenshot
On the left site a have in the block fileds form the type object. When I select a attribute I can choose the attribute and use the name of the attribute as a field.
Hope it helps
Jörg Weber
CAD Systemtechniker für AutoCAD, Inventor, Vault
KLUG-TICIANO
Hi.
Open autocad;
Charge the vba code;
Open a doc with two or more block with attributes;
Run IED;
In the formulare (left side) select "MIN" and after "MAX";
After select other bottons.
Repeat with other docs.
Bye.
Ticiano (klug@uai.com.br)
