How to DIMENSIONing a Ellipse segment
arshadmirza786
arshadmirza786
How to dimension an ELLIPSE segment like
Angle, Radius & Length etc.
imadHabash
What a deep question. this question need a lecture not a post to answer it. Smiley Wink
anyway... to get start this and using all AutoCAD features and commands to make this job easy there is some preparation that you have to make it before:
- Use proper Osnap.
- changing Pellipse system variable to 1. ( this inforce autocad to draw ellipse as a Polyline.
- Now you can get center points from the poly ellipse shape.
Either you can follow this good article >>> Article <<< .
Good Luck ...
Imad Habash
Alfred.NESWADBA
Radius? 😉
An ellipse object does not have "one" radius it can show (except of the special case of parameters making the ellipse equal to a circle).
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
