How to Dimension Using Global Variables like Solidworks
I am more confident with Solidworks than AutoCAD, but I need to know if there is a way to define values for certain lines that I can change later and have my drawing automatically adjust. I tried to store values in the command line and then use them in the dimensioning command line but I could not get the software to print the stored value.
pendean
Community Legend
Community Legend
DIMSTYLE is where you set dimensioning parameters in AutoCAD: create more than one style if needed for different settings.
HTH
johnswetz1982
Do you mean dimensioning using parameters? I don't think you can with AutoCAD but Fusion 360 will do Parametric modeling with paramters.
dgorsman
Yeah, parameters and constraints are probably the closest.  Using the term 'dimensions' here is probably a bit distracting as it has a very specific meaning in AutoCAD.
Inventor would be the closest comparison to SolidWorks.
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
