How to customize field formula?
No aplicable
Hi.
I used the following field functions to get the file name.
%<\AcVar Filename \f "%fn2">%
but there are unnecessary characters included in the first section of the file name.
Example: foo_FILENAMES.dwg
My question is, how can I  remove these characters from the file name?
Thanks.
0 Me gusta
Responder
Soluciones aceptadas (1)
3.464 Vistas
8 Respuestas
Respuestas (8)
imadHabash
The field expression to show Filename only is  %<\AcVar Filename \f "%tc1%fn2">%  , about what characters you're talking ?
Imad Habash
0 Me gusta
No aplicable
Hi imadHabash.
Thanks four your reply.
What I want to do is, get a edited file name using an field expression.
Ex:foo_FILENAMES.dwg
%<\AcVar Filename \f "%tc1%fn2">%      <- this expression return "Foo_FILENAMES"
I want only "FILENAMES".
Is there a way to remove just the first 4 characters (foo_) from the returned file name (foo_FILENAMES.dwg)
0 Me gusta
imadHabash
that field formula reflect the real existing name for your drawing , i doubt that it could be customized but you can rename the drawing file name itself , am i understand you well ?
Imad Habash
0 Me gusta
cadffm
Solución aceptada
You can do it with a DIESEL field
Check [F1] for DIESEL and Threads like this http://help.autodesk.com/view/ACD/2018/ENU/?caas=caas/discussion/t5/Visual-LISP-AutoLISP-and-General...
Sebastian
0 Me gusta
No aplicable
Filename format is determined by my company, so I can't change this X<.
I understood that it is difficult, so I will consider another way.
Thank you so much for telling me about that information.
0 Me gusta
No aplicable
Hi CADffm,
Thanks for your reply.
It seems very nice!
I will confirm the forum immediately.
Thank you for your information.
0 Me gusta
ChicagoLooper
Yes, you can easily do it with a Diesel Expression.
It is written here (Diesel Expression area).
Chicagolooper
csexcion
Great info, it helps in my case. Thanks.
0 Me gusta
