Anuncios
How to curve this 3D object?
No aplicable
0 Me gusta
Responder
1.935 Vistas
6 Respuestas
Respuestas (6)
imadHabash
i doubt that AutoCAD have the ability for such an issue and as you asked,maybe another software like (Inventor) could do it. my advice for you is to proceed immediately to draw it from scratch..
Good Luck..
Imad Habash
0 Me gusta
Patchy
Try this APP
I tried it before on new Autocad and it works on sphere but I'm can't test it on 3d curve because my Autocad is an older version now.
https://apps.autodesk.com/ACD/en/Detail/Index?id=5135633357254081302&appLang=en&os=Win32_64&autostar...
0 Me gusta
No aplicable
i cant find how to use this app,i have autocad 2016.. help me please
0 Me gusta
john.vellek
Hi @Anonymous,
That is a very tight radius for such a door section. I would approach drawing it the same way I would construct it. First, analyze what parts are cruved or not. For instance, the stiles are not likely going to be curved. So, I would place them at then ends of the curve to see what elements will need to be curved.
Next, I would sweep a closed profile along the radius for the bottom rail. Similarly you can do the top but it might take quite a bit of work to sweep the several profiles necessary for the pattern.
Again, I question how this would be built for real and would follow the same approach in your drawing.
John Vellek
0 Me gusta
john.vellek
Hi @Anonymous,
I am checking back to see if my post or others helped you with your problem.
Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please select the Accept as Solution button if a post or posts fully solved your issue or answered your question.
John Vellek
0 Me gusta
parkr4st
using autoCad 2017
attached may be close on the rails and stiles
are those ridge or grooves for the detail?
the panel detail is ridges or grooves?
dave
0 Me gusta
