How to create Isometric / Axonometric Brick or Tile Hatch Patterns for 2D?
Message 1 of 33
As can be seen from the photo attached. The tiled, brick like flooring is aligned isometrically. I tried to do it after importing a 2D-Isometric CAD file from a SketchUP model, but the brick pattern on AutoCAD just do not align exactly as my isometric drawing. Adjusting the angle of hatch DOES NOT WORK. As it will only change the angle of either the Horizontal OR Vertical brick but NOT both...
Please help! Really desperate now...
Accepted solutions (3)
Replies (32)
Message 2 of 33
imadHabash
can you attache here just the part where the hatch exist for testing please ?
Imad Habash
Message 3 of 33
Hi, as attached is the file. The walls are made of Bricks. But I figure it is impossible to draw bricks one at a time. I am sure there is a way! 😞 I am so desperately in need of solution now... 😞
Message 4 of 33
imadHabash
Unfortunately ,  isometric hatch is NOT applicable .   😉
Imad Habash
Message 5 of 33
So there is no way to achieve that...? 😞
Message 6 of 33
imadHabash
honestly and as much i know ... you have to draw it manually .  !!
Imad Habash
Message 7 of 33
oh my gosh... Alright. Thanks!
Message 8 of 33
hugha
All you need are a pair of 2D isometric brick patterns.
What size brick?
What size gap or no gaps?
Even better, post the  orthogonal pattern you want to use.
Hugh Adamson
hatchkit.com.au
Message 9 of 33
D_Will_1987
This what what the copy command is for. Draw one full brick/tile/strip of flooring. For the next row, make a half-brick/half-tile/shorter length of flooring. Copy both of them. Then Copy the 4 items. Then copy the 8 items. You can double the number of copies each time you copy. Also:
1) Isometric is **** for architectural representation. This drawing problem has all the hallmarks of a bad university CAD exercise slapped together by a TA. A better way of showing architectural spaces axonometrically is by using Plan Oblique. Here's a cool article on how to set up SketchUP to display a Plan Oblique:  https://visualizingarchitecture.com/plan-oblique-illustration-part-1/
2) For flooring and other less-than-important hatch patterns, try setting the lineweight of the layer to 0.00 mm. You'll still see it, but it will be much thinner than the default line, and fade into the background.
Message 10 of 33
hihi,
just a regular 215 by 160 brick. With no gap 🙂
Thank u!!
Message 11 of 33
hugha
try these:
;        Written by HatchKit Team Edition
;        HatchKit Team Edition (c)1990-2019 Cadro Pty Ltd
;        www.hatchkit.com.au/
;-Date                                   : 2019-04-22
;-Time                                   : 19:54:39
;-HatchKit Team Edition Version          : 3.1.11.2776
;-HatchKit Team Edition Output Filetype  : AutoCAD format
*BrickIsoLeft
-90,0,160,97.94025,-107.5,160,-160
150,0,0,0,138.56708
*BrickIsoRight
-90,0,160,97.94025,107.5,160,-160
30,0,0,0,138.56708
hth,
Hugh Adamson
www.hatchkit.com.au
Message 12 of 33
Sorry if this sounds amateurish, but what do I do with these coordinations? 😞
Thank u for the help!!!
Message 13 of 33
j.palmeL29YX
I would use this code to create two new text files with the extension .pat (as in the attached .zip file) and store this files anywhere in your support path.
Now you can use this patterns as shown in this Video
Or you can add the code to your *.pat file.
Jürgen Palme
Message 14 of 33
Kent1Cooper
Try these.  The number in the file/pattern name is the angle in degrees of the continuous-line parts.  But I must ask -- are those the right dimensions?  The bricks in the floors in your image look like a longer proportion.
[The HatchKit patterns from @hugha are oriented for wall usage rather than floor, and the lengths of the bricks is not what you asked for.]
Kent Cooper, AIA
Message 15 of 33
Oh wow!!
Thank u so so much for the attached file AND the video! U are too kind! 🙂
Message 16 of 33
Yes these bricks are for the walls. The image shown is an example on the effect im trying to achieve (which cannot be without using all these "codes").
Nonetheless, thank u 🙂
Message 17 of 33
*Edit: IT WORKS! THANKS 🙂 *
Message 18 of 33
Thanks a lot @hugha @j.palmeL29YX and @KentlCooper !
U guys are amazing 🙂 Didn't know we can do such customization in AutoCAD! Was really desperate before u 3 solved my problem effectively! Thanks again!
Message 19 of 33
Kent1Cooper
@Anonymous wrote:
Yes these bricks are for the walls. ....
I guess you've figured out that you can use mine at appropriate rotation angles to get the wall usage, but here are some that include Floor and Wall in the names, so you can use the appropriate one at zero rotation  for each application.  [The ones for Floor are the same as before, but with the Floor part added to the file and pattern names.]
Kent Cooper, AIA
Message 20 of 33
Oh wow! U are way too kind! Thanks a lot 😄 This helps me a lot!
