How to create custom numbered circle annotations like in picture attached.
spetropoulos
spetropoulos
How can these be made?
Patchy
Use TCIRCLE command on a number.
TerryDotson
You could make a block definition containing the circle and an ATTDEF, then use the block option of the MLEADER command.  During usage it's a bit of repetitive prompting because it doesn't seem to remember the parameters you used last.
If you were to consider third party software, DotSoft's ToolPac contains a Leader w/Bubble and Adjacent Bubble tools to speed up this process.
spetropoulos
I figured out how to at least use the spline leader, however I would like to have two inflection points to have more control of the curve. But yes, as you mentioned the mleader function forgets the parameters after I set it. There is no way to set this as default?
I've never used Attribute Definition before, how would I use this to create what I want?
spetropoulos
thanks this may be helpful as well
Edit: I tried this and it does not work on MTEXT within an mleader annotation
jggerth
To get more control points for a splined leader, select the leader, and hover on the END vertex.  you'll get the option to add a new vertex as the new end location.  After that, you can hover over any of the intermediate grips, and add additional vertices where ever you like.
jggerth
Create a new MLeader style, and on the content tab, select block as the Type,  One of the default source block is "CIRCLE"
