How to Create Complicated LineType?
viper_007
viper_007
Hi! I want to draw lines with linetypes like the pictures show.  However, it seems impossible to make the linetype. I really need your help.
Linetypes are outlined with red pen.
聚傲气于一身,显傲骨之精华
0 Me gusta
Responder
Soluciones aceptadas (1)
761 Vistas
11 Respuestas
Respuestas (11)
TheCADnoob
0 Me gusta
Pointdump
V,
Easy as pie. Here ya go:
http://www.cadapult-software.com/creating-linetypes-with-measure-and-divide/
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
0 Me gusta
viper_007
I can't believe you make the "linetype" in this way., good idea.
although it looks great, the lines are not real lines, it's unconvenient to edit or snap the lines.
聚傲气于一身,显傲骨之精华
0 Me gusta
Michiel.Valcke
I learned how to make linetypes from youtube.
I guess the best way to share this knowledge is by sharing the link ^^
Kent1Cooper
The black arrowheads and the gray C's or U's or whatever they are could be done with a complex linetype definition with embedded text, if you can find a text font that has appropriate shapes [Wingdings or a similar symbol font for the arrowheads, various possibilities for a C or U that would be usable].  Help will tell you how to make those.
The ones that have width and multiple colors can't be done in single linetypes, as far as I know.  They would probably need to be done with multiple Polylines of different colors [whether assigned to the Polylines themselves or on different Layers] and widths.
Kent Cooper, AIA
0 Me gusta
Michiel.Valcke
You can combine colors and different linetypes with a Multiline. The Autodesk Knowledge Network has an article about it here
0 Me gusta
Patchy
Dynosaur mline can't even make a curve, it's useless and shouldn't be called a line making tool.
Kent1Cooper
@Michiel.Valcke wrote:
You can combine colors and different linetypes with a Multiline. ...
But not the width in the OP's image, as you can do with Polylines.
Kent Cooper, AIA
0 Me gusta
viper_007
For example, I make a linetype file with code like this
*JustForTest 2
A,0.01,-0.1,["♥",STANDARD,S=0.1,R=90,X=0,Y=0]
I just want to see the custom special maker without any short lines between the makers. neither the beginning or the ending.
I can't figure out.
聚傲气于一身,显傲骨之精华
0 Me gusta
john.vellek
Solución aceptada
Hi @viper_007
*JustForTest 2
If you change the first value to 0 or to something like 0.000000001 does that work for you?
Here is an AKN Article that describes the Linetype definitions.
John Vellek
0 Me gusta
viper_007
*JustForTest 2
A,0,["♥",STANDARD,S=0.1,R=90,X=0,Y=-0.042],-0.1
Thank you very much!
It helps me a lot.
聚傲气于一身,显傲骨之精华
0 Me gusta
